I need to replace the CMOS battery
SOURCE: Where can i download Asus P5GC MX/1333 Motherboard drivers?
Hey,
drivers and software for your motherboard p5gc mx 1333 are available on this asus page
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5GC-MX/1333
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: COMPATIBLE GRAPHICS CARD WITH P5GC MX/1333 ASUS
Yes you can put a 1 gb card. The motherboard has PCI Express so you don't have to worry to much. The older AGP cards are almost gone.
You could buy a GeForce 8500, 8600, or 8800, or the 9 series. You can also buy a Radeon HD 5870 or 5570.
If you need further assistance, please post. And do not forget to rate.
Thank you for using FixYa
SOURCE: ASUS P5GC-MX/1333 - Audio driver
my mb p5gc-mx have problem with audio driver. each to install the audio driver. failure. I try to install with aother cd p5gc-mx. but afailure again. how to install the audio driver. so my audio can hear?
SOURCE: i have asus p5gc mx x-series motherboard and
connection manual pics i need pls help me to connect my audio connection in mother board
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge Cmos battery on some motherboards are soldered in
hope this helps you
