I'm trying to remove the back cover to possibly replace a capacitor. I took all the screws out and took it off the stand but still can't get it open.
SOURCE: removing stand to mount on wall
Just called the company and was told that you simply remove the 4 screws on the back of the stand that is holding it to the tv....They do NOT recommend mounting the TV because it will make your warranty ineffective-per the rep.
SOURCE: What screw holes are used for wall mounting a Sylvania 37 in LCD
the tv only weighs 55 lbs yes those are the holes 4 of them your bracket may have other screws if the bracket is thick
SOURCE: my tv will not pwr up. grn light flashes then turns red.
I have a Sylvania LD320SS8A and I turn it on and the green light comes on and no picture???? Just black... I can hear some sound but no picture...
SOURCE: I need to adjust the horizontal/vertical picture
there is no adj you will have to change pix. format
SOURCE: I have a Sylvania LC370SS8
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
