I've tried the 30sec. reset.When I plug the TV in the wall the logo flashes orange and white,then it stays orange.turn the TV on the logo is white, the screen turns white then goes dim and black screen
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
SOURCE: Model VS42LFHDTV10A. The TV is
This may be the problem of relay switches. It can be replaced to eliminate such errors.
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by
meg_car on Jul 08, 2009
Service by: mjsazon
