Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
How can I remove date from pictures on Canon 130 IXUS
6ya staff
SOURCE:
old marine
old marine
  • 2277 Answers
SOURCE: Canon Ixus 850 IS
In order to use the date stamp option, the image size (L, M1, M2, M3, S, Postcard) has to be set to Postcard. Press the Func/Set button, scroll down to the image size icon (lower left corner), then scroll over to Postcard, and press the Func/Set button again.
Posted on Jun 10, 2008
Anonymous
SOURCE: Date and Time
Do you have the Camera User Guide~~~It tells you how to set it on p37
or
I found this on the Camera User Guide
steps
1.press the function/setting button
2.on the left side,there's a column displaying various features, and then you go to select the very last one, and then it will displays more options for you to choose(L,M1,M2,M3,S, postcard,etc), and then "postcard" is the one you should choose.
3.After that, go to "menu", go down to the very bottom on the option list, you will see that the "Date Stamp" is being set "off", go there and choose other options (date/date and time). This is how you can display time on the pictures.
Posted on Jul 14, 2008
smartr10U
KEN LaPOINT
  • 1305 Answers
SOURCE: i am not gettin any
Check your settings in the menus. If you've muted the camera to remove the other sounds, it will mute the video soundtrack as well.
Posted on Jul 31, 2010
jgroves705
Jeffrey Groves
  • 573 Answers
SOURCE: How can you remove the
Assuming this is actually a Canon IXUS 82 IS (not an 8215 which doesn't exist), I found on page 20 of its user manual that you have to do the following:
Slide the Mode switch to the top setting Press the Func. Set button Press the right or left arrow until you see the camera icon that stand for "Auto" (see manual) Use the up and down arrows to select the "L" Use the right or left arrow to select the last icon at the right that looks like a clock in front of a picture Press the DISP button Use the right or left arrow to de-select [Date/Time]
I suggest that you look at the user manual directly, since some of the above doesn't make a lot of sense without seeing the icons.
Thanks for using FixYa and Happy New Year!
Posted on Jan 05, 2011
lock123
Andrea Lock
  • 6831 Answers
SOURCE: My Canon IXUS 130 camera
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on May 06, 2011
Canon IXUS 130 manual
The Canon IXUS 130 is called the SD1400 in some parts of the world. You may download the SD1400 manual from here.
Dec 02, 2012 | Cameras
Hi, how do i remove the date thats stamped on all my pictures. I have a canon ixus 105
Press MENU button.
Use Function Button arrows to bring up the camera icon at top of screen.
Use Function Button up or down arrows to get to Date Stamp heading on screen.
Press right arrow to get Date or Date and Time.
Select OFF
Press Menu
Done
Jun 28, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Cannot connect a new Canon Ixus 130 to Windows XP PC - have already installed ZoomBrowser EX 6.5.1
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use ZoomBrowser or any other photo cataloging program.
Dec 08, 2010 | Canon PowerShot SD1400 IS IXUS 130...
How can I get the date to appear on my pictures for downloading ?Canon ixus 75
On my Ixus 70, I can only "embed" the date on pictures when "Postcard Mode" is selected. Press "Func/Set", go down to the bottom icon on the left (sets picture size) then go right to "Postcard" (looks like mountains, will say Postcard when selected) then press Func/set button again. Now press "Menu", scroll down to "Date stamp" and set it to "Date" and press "Menu" button again.
Once embedded, the date cannot be removed later.
Nov 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Cannot take a shot
"It can take very clear and vibrant pictures, and it lives up to the high expectation that the IXUS/Powershot brand has forged over the years, particularly for premium models such as this one. However, its button design and build quality are from perfect and can make the camera frustrating to use. Nevertheless, if you want a very small camera that can capture great images, it's hard to overlook the Canon IXUS 130 IS/PowerShot SD1400 IS."
Oct 20, 2010 | Canon PowerShot SD1400 IS IXUS 130...
Canon ixus 130 manual
Hi..to respond about your Canon ixus 130... Try to download it from internet example...from any browser, exemple type...download canon ixus 130 manual, then copy the manual on a safe place on your pc. good luck.
Oct 13, 2010 | Cameras
E32 error with canon ixus 130
I have purchased recently canon ixus 130, the camera automatically shuts down after some 30 sec& shows a messege 'camera error,restart camera will autometically shut down error
E32.'
Jun 06, 2010 | Canon PowerShot SD1400 IS IXUS 130...
I can't find the manual for my didital ixus 700 and need to delete some photo's but they have been proteced, i don't know how to remove the protected status?
Here's the manual (free to download):
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IXUS%20700-_E
Protection / unprotection of pictures is dealt with on page 130.
Note that FORMATTING a card will delete ALL pictures (irrespective of protection).
Hope this helps
Mar 09, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
How to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
dsc_include_date01_tcm13-520510.jpgTo set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm13-520511.jpgBe aware that if you take pictures with this option enabled, the Date and Time cannot be removed from the pictures at a further time. It will permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
Feb 28, 2010 | Canon IXUS 860 IS Digital Camera
Taking the date off the pictures I take with my Canon Ixus 80 IS
Go to www.canonUSA.com, you can download the manual for the american version of the camera - the POWERSHOT SD 1100 IS
Instruction to turn on and off the date function are there.
Jan 20, 2010 | Canon IXUS 80 IS Digital Camera
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
952 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
