I have been 3 weeks not receiving traffic on my navigation. sirius xm sent several signals. Acura dealer checked and spoke with sirius xm also. I receive all sirius radio stations fine, but without traffic. have 2nd vehicle on same account not problems.
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
SOURCE: great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
SOURCE: Stations dropped
go to refresh.xmradio.com and insert your radio ID and click submit. It will resend the activation signal and should unlock your channels within 15-20 minutes.
SOURCE: XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
SOURCE: xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
SOURCE: no signal problem on xm home satilite docking staion
You have probably lost a local repeater. Try moving it temporarily to a south-facing window. Here's another one to try: Put in dock and turn off with button on unit. wait 10 seconds, now press "2" "0" "7" "XM" buttons one at a time in that order ON THE FRONT of your SkyFi2 and the radio will go ON by itself! Now, press "Display" 4 times. You will see a screen that says "SAT1", "SAT2" and "TERR". You need a constant checkmark for DEMOD on at least one of the 3 boxes. Please tell me which ones are checkmarked and the average "BER%" number is. The lower the BER% number, the better. If BERis 100%, you are out of luck. Write back and let me know what you read. Press "Display" 5 more times to go back to regular screen. Thanks,
John
