Question about Canon PowerShot SX110 IS Digital Camera
Flash is stuck on off position - Canon PowerShot SX110 IS Digital Camera
High beams flash but don't stay on
you'd have to play with it and see if it's related to maybe a stuck fog light or simply the high beam switch is junk
Mar 25, 2014 | 2006 Pontiac G6
Canon 380ex
I had a similar problem with my 430 EXII flash recently and discovered that after using the flash head in a "bounce" orientation, where the zoom automatically sets itself to 50mm, It wouldn't go back to wide angle or telephoto when I folded it back into place. The problem was caused by a small piece of confetti preventing the head from fully resting in the forward position. Check to see if there is any debris caught in there.
Dec 15, 2013 | Canon Cameras
How do i reformat a data traveler kingston 2 gb usb flash drive? i tried formatting but it shows that it is Chipsbank usb flash drive with only 8 mb memory and then it wont complete formatting when i...
Are you positive there isn't a flash drive stuck in a USB port somewhere else on the computer? Very peculiar for the computer to be recognizing a completely different device.
May 18, 2011 | Electronics - Others
550 ex zoom stuck on manual
Hi Liz,
Because this thread is more than a year old, I sincerely hope you figured out the solution to the zoom problem with your flash. I was having the same issue with the 550ex and found the simple solution on a forum about Canon Flash Photography.
Make sure that your diffuser panel (wide panel) is off and securely seated in the top of the flash unit. When the wide panel is in the down position, it forces the flash into manual mode at the widest setting.
Hopefully this little tip will come in handy for someone out there reading this thread.
Mar 05, 2011 | Canon Speedlite 550EX TTL Flash
The turn signal, stuck on constant blink, take the bulb out still constant on the dash sig.
sounds like the turn signal cam in the steeringwheel might be broken, stuck in the open position, poss. causing it to flash continuously. Hope this helps.
Jan 29, 2011 | 1994 Mercedes-Benz C-Class
My Cd Player in my car wont take in any discs
Hello you probably have one stuck inside use a flash light press eject and see with your flash light if a disc is surfacing sometimes they get stuck and need a little bit of pres-wading.if this is not the situation perhaps your cd carriage is stuck in eject position if so you will need to have a service technician repair it.
Jan 08, 2011 | 2000 Ford Focus
The flash on my Canon Rebel xti is not working. the flash pops up, but it is not lighting. I saw some responses about people using q-tips and alcohol, but I do not know what exactly you mean and it is...
I think people were talking about cleaning the flash shoe, in case you use an external flash. However, there is a microswitch under the rails of the hotshoe on top of the camera that could be stuck in the down position.
If that's the case, some people use a toothpick to release it to the "up" position. If this switch is stuck, the camera thinks you have an external flash attached and ignores the popup flash.
The little pin people are talking about is the switch beneath the rails of the hotshoe. You might try to use the qtip and alcohol if it looks dirty. Take the camera in to a repair shop and just ask them where it is if you're still having a problem identifying it.
Good luck, and hope this helps.
Sep 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
How do I make my dscw55 only flash once instead of the delayed one
You can change flash modes with the control button.
Your camera has three flash modes.
First Position:
Flash forced on. This is the position that you want to use.
Second Position:
Slow Synchro Flash forced on. In this position the flash strobes twice.
Third Position:
Flash forced off.
I offer you to use the first position. In this position normally, your camera strobes for one time.
Apr 29, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Main beam stuck on and no dipped beam or flash
Either the relay itself has jammed or the flasher arm is broken in one position. Much more likely to be the relay. But before replacing the relay, check the fuses that supply it as if the supply is interupted, can cause it to "lock" in one position
Sep 28, 2009 | 1986 Volkswagen Wagon Camper
Canon PowerShot SX110 IS Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
