Audiovox SP11CDP 10-Disc CD Changer Logo
Posted on Jun 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the changer fuze located on an autdiovox
Where is the changer fuze located on an audiovox SP10 CD? My magazine will not release and I get a "no dj" message on radio screen. I checked power cable and power is present at changer end of cable. Thanks for your assistance.
Frank Fulton
Level 3:
President:
  • Master 1,114 Answers
  • Posted on Jun 26, 2009
Frank Fulton
Master
Level 3:
President:
Answers
1114
Questions
Helped
502507
Points
3541
It's not a fuse. More than likely it tried to load 2 discs into the same slot and jammed. That's one of the most common problems with shangers. If you pull the unit out of the vehicle and open the top you will see how it's jammed. Lightly move the CD towards the tray side, not into the cartridge, then plug the unit back in. It will reset itself and then you can eject the cartridge. Then inspect the cartridge for warps or cracks. You may want to replace the cartridge, they do wear out. Also, a good habit is to run a Laser lens cleaner thru the unit itself 3 or 4 times a year to keep the lens clean. It's really the only maintanance you can do. Hope this helps
My original problem WAS that the magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame INSIDE the...
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
I am looking for an Audiovox MVCH10A 10 disc DVD/CD Magazine. Can anyone help me locate one??
I am looking for a remote... if I cant find a remote I will sell you the unit if you are interested?
Cant remove magazin with cds without changer is on power
Is there a pin-hole on the front of the cassette? If so, insert a paper clip into the hole to manually release the cassette.
2answers
Manual removal of cd magazine
Seems to me an error of the installers, just go back and ask them to remove the magazine properly.
Replacement disc magazine
manufacture of make of cd changer but it would be cheaper to buy new cd changer i would think but worth you checking
1helpful
Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
