SOURCE: Navman iCN 520
The CD is not available for download from Navman it seems, but you can get it at thepiratebay.com. Just search for 'navman icn' and you'll find what you need, I just did. Better learn how to download torrents though! :)
SOURCE: navman icn 320
carefully pull off front grey cover with your thumb, next to card socket, underneath are 4 security screws you need a small torque head screwdriver, take off cover losen security screws inside around battery, unplug and remove battery, replace in reverse.
SOURCE: Navman iCN 550 GPS frozen on start up screen and makes a noise like it is stuck
Try hitting your reset button if you haven't already. I had the same problem and this worked for me.
SOURCE: coordinates for navman s50
Hi there, thanks for your time, it seems it is not possible to get coordinates on my model of navman, regareds, Barry Hall
SOURCE: continual "waiting for gps " message
the message should also read no mnsa data first... if these units are not in continual use,they get corrupt for some reason. all you can do is hope the gps fix will work itself out,otherwisw buy a new unit.
