Will only print if the ok is pressed two times
SOURCE: Problem While printing
Hi there it seems to me that you have the printer driver set incorrectly.
First on the computer click on
Start
Then Control panel
Printers and Faxes
once in there right hand click on the pinter and select printing preferences.
Select the tray you wish to use as your default. Ok and exit that.
On the printer press the green tick button move the up or down arrow until paper handling is displayed. Select which feed either cassette or MP then sizes for this tray. Once that is complete select what media type the paper is i.e. plain preprinted or others.
(You may have to do that in the printing preferences within the driver as well)
That all going well you should now be able to press the print button and the page will come out from where you asked it from and with out pressing any buttons.
Hope this was of some help.
J
SOURCE: Printing from the photo tray
I have found that when you put the photo paper in to the photo tray you have to slide the photo paper in to the printer gently as far as it will go, then slide the side and rear guides to the photo paper. If you just put the photo paper in to photo tray without doing this, the printer will not take up the photo paper at all.
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
SOURCE: hp laserjet p3015 pausing after 5 or so pages
I have seen this problem before. Basically what is happening is the fuser is losing it's heat. When the printer pauses it is waiting for the fuser to get back up to temperature. The first course of action would be to reinstall the print drivers. This will rule out the communication aspect. Then to replace the Fusing assembly (fuser) and if that doesn't work to replace the Power supply.
If it is the power supply it wouldn't be worth the time or money to repair the printer based on the original cost of the machine.
SOURCE: HP P3015 suddenly printing very slowly - about a
If you unplug the cable from the printer to the PC and print the MENU MAP, does it print slow or at normal speed?
If it prints slow, try following the directions below.
If it prints at normal speed, try removing the printer from the print queue and reinstalling it. Also, download the PCL5 drivers and reinstall it.
Good Luck.
Print a MENU MAP and a CONFIG page.
You will need this info to put the settings back in the printer.
1. Turn the device off.
2. Turn the device on. When the memory count begins, press and hold the CHECK MARK button. Continue holding
down this button until all three device control-panel lights flash once and then remain on. This
might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the ^ button
until COLD RESET is highlighted.
4. Press CHECK MARK . The device performs a cold reset and then continues its power-on sequence.
5. Check all I/O settings and reset any customer-set device configuration values.
COLD RESET sets ALL control panel menu items, including network settings back to factory defaults.
This is where the MENU MAP and CONFIG info come into play.
