Question about Onkyo TX-8211 Receiver
Why is there no volume to the reciever - Onkyo TX-8211 Receiver
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
I have a JVC A-L55 and I just plugged it into a reciever. It is working fine but the volume is very low. I have to turn the volume on the reciever all the way up to hear it. The reciever is attached to new...
You need to find out if your reciever has a "magnetic cartridge pre-amp" built in. Many don't and it's no good putting it in an aux or tape socket. If it doesn't say 'phono' or 'record player' on the socket it probably won't have one. Don't worry you can buy one, which will restore the normal sound level.
If it does have one it could be faulty. They are often a single IC that has failed, but they tend to kill the sound dead when they fail, so I don't think that will be your problem.
Just put the words "magnetic cartridge pre-amp" into Google to find one.
Nov 16, 2010 | Audio Players & Recorders
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
Low sound at high volume
THe problem is with the variable resistor present behind your volume control knob, try replacing the volume controls variable resistor, this must work fine... this is a common prblem for all the music equipment that has knob control for the volume....
This resistor can be replaced with your product warranty, contact your seller for the details regarding warranty...No need to woory about this, this is a sommon problem for most of recievers
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 04, 2009 | Sony STR-DG1100 Receiver
Protect displaying
Protect on any reciever usually means that it has reached its maximum capacity of volume (known as clipping) and at the reciever is now automatically reducing the volume to avoid damage. This some times is triggered if the reciever was used hard and is now damaged so you would need to bring it to a repair shop. Sometimes its caused by a bad wire to the speakers, a short to say. Check all your wiring, make sure its not overheating and getting plenty of air. Some where its recieving a signal telling it to go into protect mode.
Joe
May 28, 2009 | Audio Players & Recorders
Have no volume on only one channel on Panasonic TH-42PX60U
Try the SAP - same thing happened to me and had to cycle through the audio tracks to get audio back on for that one channel. Good Luck!!!
May 12, 2009 | Panasonic TH-42PX60U Television
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Center Channel is failing itermittently
some of the theater selections sometimes effect this i think. check different fields also.
Jan 11, 2007 | Yamaha HTR-5280 Receiver
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Dec 31, 2006 | Denon AVR-2801 Receiver
Onkyo TX-8211 Receiver Logo
57 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
