Question about Minolta Maxxum STsi QD 35mm SLR Camera
Why is a black border around my developed film?
    Top Expert:
  • Minolta Master
  • 6,705 Answers
The black border around your film is the part that did catch light. The light on dropped on a negative film comes up black. If the cassette the file was in had a leak, and it was in bright light, that could be the culprit. But if a second silk also has a black border, check the camera, if there is a possibility light can come in on the back.
Posted on Jun 19, 2014
6ya staff
SOURCE:
Two rolls of film developed at CVS - apparently not exposed???
it is not unknown for film developing sites to with hold good photos so take another practice roll and have it developed somewhere else
That will prove either the camera or the developer
Apr 23, 2017 | Pentax K1000 35mm SLR Camera
Tip
Step by step guide for rolling a film reel for developing
Rolling film on a metal reel can be very challenging and for years I avoided using these reels in favor of the plastic ones with the large lip for leading the negative around the reel. Over the last year or so I have been working on getting around this fear of not being able to roll the film.
The first and most important thing that you have to make sure is that when you cut off the "L" shaped piece make sure that you cut the film between the sprocket holes. Those first few holes are crucial for the ability to successfully loading the film on to the reel.
On the center post of the reel there are two very small hooks that you want the negative to hook on to using those sprocket holes. These hooks work to make sure that the film stays put while you roll and throughout the development process.
Once the film is hooked on you are going to slowly turn the reel around and around holding the unrolled film on the sides. Make sure to hold on the sides because you don't want your fingers to scratch the very sensitive negative.
If you practice in the light with dead rolls of film you can check if you rolled well by holding up the roll and looking though. If you can see between the rounds of film then you have done a good job. It is important that the film be rolled smoothly because if parts are touching then the chemicals can't get in and the film will not develop properly. Once you have mastered rolling this way in the light take some time to roll a dead roll of film in the dark before you get to the real stuff (no pun intended).
on Oct 03, 2013 | Photography
Hi, well firstly, my pictures are really blur and un-focused when i take them from a distance away. secondly, my developed photos have black border lines on both sides of the photo or 1 on the left/right...
I have the same issue with the borders being black , i think its because the 24/24 setting ie square shot is selected and the developers print on rectangular paper ,I may be wrong. On the bluring have you changed the focus on the front or have you got it set on B as both may have this effect . hope it helps
Narbs
Apr 24, 2011 | Lomo Diana Mini 586 Film Camera
I dropped my instax 210 because the strap came undone. Now when I take pics, there is a part of the shot that remains white. Is something cracked inside? Should I just buy a new camera?
It may be because the film chemistry is not being activated in that area. As the film is ejected it gets suqeezed to spread the chemistry thru the whole picture for developing. Try a bit of manual rubbing on the back of the picture, from the bottom (thick border) to the top, as soon as it is ejected.
Nov 06, 2010 | FUJIFILM Instax 210 Film Camera
I have a sony hvr-z1j...and when I log filmed footage onto the computer there is a thick black border around the (16:9 or 4:3) visuals. There is no sign of the border on the lcd screen or viewfinder when...
Ha this sounds like you may have accidently pressed the AV button, it has special borders and setting within the camera, these are used for title effects and other tricks, just press the button again a couple of time filming and see if it vanishes.
May 20, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
Developed film pictures have black around the edges
My guess would be that whatever lens your using is causing that. The black edges are basically caused because the lens may not be fit the camera correctly, causing the camera to "see" part of the lens itself when taking a photo.
May 03, 2010 | Pentax Photography
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Dell Inspiron 8200 Notebook
Nothing shows up on the film!
The Ilford Delta 400 Professional is indeed DX coded. Since the camera does not allow you to check the shutter without film inside, there's no way we can confirm the shutter is working properly. So only option is a service center. Since all other things are working properly, it should be a simple repair.
Feb 11, 2009 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
Film developing clear
Hello
This problem could have a number of causes,
To check to see if it is a camera fault of developing fault you could try using a cheap colour film in the camera and getting it developed at a normal photo processor.
This will determine in which half of the process the fault lies.
If the pictures from the colour film are the same then it must be a camera usage problem or fault.
If the pictures are ok from the colour film then it will be a problem in either the film being used, developing problem (poor mix of chemicals etc).
This will just speed up the diagnosis a bit.
Oct 02, 2008 | Pentax K1000 35mm SLR Camera
Minolta Maxxum STsi QD 35mm SLR Camera Logo
61 people viewed this question
Top Minolta Photography Experts
Ekse
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
