Hot water enters washer fine - cold has gone down to a trickle within the past few months. Hoses are not kinked & faucets are completely open.
SOURCE: Water does not enter
PLease check the water inlet filter. This is normally located just where the cold water hose connects up to the machine
SOURCE: Hot water is a small
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to
fill then read these tips. I have covered many of the things that can happen in
these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
SOURCE: washer don't get the cold
(this covers both hot and cold but please read for cold! Your hot water supply provides the extremely hot water and is normally mixed with cold in the washer for the correct temperature.)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
