Nortel bmc50 manualcan be used for installation or maintenance referencing in case you own bmc50 business communication manager This BMC is excellent choice for small to medium...
Dear Annabelle, Is the machine call pilot 100 or 150.if 100 the 2 leds in your left hand side should be on also in your right hand side the middle led should be on same for 150 the 4 leds in your left hand side should be on.1) Try to unplug the power cable and re-connect it again.2) Make sure that the the output telephone cable [100 (2 pair) or 150 (4 pair)] depends on the device comming from the call pilot to the Nortel PABX connected properly from both sides. dont hesitate to contact me if you are facing any doubt.Goodluck and Kind Regards; Ahmed Safaa El-DeebTelecom & Network Engineer
If you have a call-pilot 100 or 150, access the call pilot manager. Then go into the Autto Attedant menu and select line administration. You will see each line listed and the ring count displayed.Click on "change" on and then adjust the rings. The call pilot manager is a GUI you access inside the call pilot through the cat 5 plug with a crossover cable. The default IP is 192.168.110.11 with a mask of 255.255.255.0. default logon is 0000.
Bill C. www.dyna-tech.us We also offer remote programming for the Nortel CICS and MICS.
Here's the cheat sheet you were looking for. Here at IdacomUSA we provide User Guides and System Manuals for every system and phone that we repair. We also repair the Nortel T7316E for $75, which will transform your old phone into one that looks and works like it was purchased yesterday.
I think the best thing I can do is give you the link to the user guides so that you can pick the one most suited to your application, as Call Pilot has many facets ... Good Luck
