SOURCE: NEED MANUAL FOR SPEED QUEEN DRYER MODEL
Look on this page for your model
http://www.eaaxon.com/pdf.htm
Is Parts only mostly.
SOURCE: Dryer doesn't throw hot air
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Testimonial: "Thank you so much you saved me time and money"
SOURCE: dryer will not heat up Does run
It's probably the thermostats that are normally attatched to the element or it could be the element itself. They are nprmally placed in the rear of the appliance.
The thermostats will only cost a few pounds.
SOURCE: speed queen electric dryer shorted circuit bracker
Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: i have a speed queen gas dryer. do i have to
You do need to turn gas off and be carefull when shoving vac noz around flame tunnel because the glow ignitor is very fragile and breaks easily.
