If you need to replace the printer, i would suggest to buy compatible toner, you will save some money doing this. the technology for compatible toner has improved greatly in recent years, you should have no problem using it. i usually buy my ink toner from this website:
Brother Toners Inks Cartridges or
Amazon com Online Shopping for Electronics Apparel Computers Books DVDs... if they have something with prime. Watch this video
it might help you print with empty cartridge :)
No, if one of the cartridges runs out of ink the printer will not let you continue. It is a common complaint with this model. However, I have had great success with refilling the cartridges.
The printer apparently keeps track of number of pages printed instead of whether the toner is actually low. Here's a reset that I found on Amazon:
1. Open the front cover that gives you access to the toners.
2. Press and hold "Secure Print" and "Cancel" at the same time. You will see "K-TNR-STD" display on the screen.
3. Using the "+" and "-" buttons select the toner you want to reset.
4. Press the "Ok" button.
5. It will display "Ok?" and hit the "Ok" button again to reset the toner.
6. Close the lid.
Hope this helps.
To order print cartridges:
}}--> }}-->Open the }}--> }}-->Lexmark
Solution Center
}}--> }}-->Click the Contact Information tab.
}}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print
cartridge.
Follow these instructions when the ink level is low.
Note When the ink level for the print cartridge is low, a message appears on
your computer screen. You can also check the ink levels by using the software
installed with the HP All-in-One.
When you receive a low-ink warning message, make sure you have a replacement
print cartridge available. You should also replace the print cartridges when you see
faded text or if you experience print quality issues related to the print cartridges.
To order print cartridges for the HP All-in-One, go to www.hp.com/learn/suresupply. If
prompted, choose your country/region, follow the prompts to select your product, and
then click one of the shopping links on the page.
For a list of print cartridge numbers, see the back cover of this guide.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Open the print cartridge door.
The print carriage moves to the center of the HP All-in-One.
3. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 8
28 HP Deskjet F300 All-in-One series
Maintain the HP All-in-One
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge. The HP Inkjet Supplies Recycling Program is available in many
countries/regions, and lets you recycle used print cartridges free of charge. For
more information, go to the following website:
www.hp.com/hpinfo/globalcitizenship/environment/recycle/inkjet.html
6. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
User Guide 29
7. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If the print cartridge alignment sheet prints, load it on the left front corner of the
glass with the top of the page to the left.
10. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print
cartridge alignment sheet.
