Re: How do i remove the gas control valve hermostat
Do you mean the pressure relief valve on the front? if s it will turn. it is just has caalcium buildup. if you mean a water valve behind the water heater. it will come off. it is probably just a PEX fitting. you will have to replace it. home depot has all the fittings
Locating the water heater bypass on a Forest River RV, specifically the Forest River Georgetown 398 model, can vary based on the specific layout and design of the RV. However, in most RVs, including Forest River models, the water heater bypass valves are typically located near the water heater unit itself. Here are some general steps to help you locate the water heater bypass on your Forest River Georgetown 398:
1. **Identify the Water Heater Unit:**
- The water heater in your RV is usually located inside a cabinet or compartment, either inside the RV or accessible from the exterior.
- It is commonly found in the kitchen area, bathroom, or an exterior compartment.
2. **Access the Water Heater Compartment:**
- Locate the compartment where the water heater is installed. This could be inside the RV or in an exterior storage compartment.
- Open the compartment door to access the water heater.
3. **Look for the Bypass Valves:**
- Once you have located the water heater, look for the bypass valves near the water heater unit.
- The bypass valves are used to redirect water flow during winterization or maintenance to bypass the water heater.
4. **Check Behind the Water Heater:**
- In some cases, the bypass valves may be located behind or on the backside of the water heater unit.
- You may need to remove a panel or access door to reach the bypass valves.
5. **Identify the Bypass Valve Configuration:**
- The water heater bypass system typically consists of three valves: a cold water valve, a hot water valve, and a bypass valve.
- The bypass valve should be set to bypass the water heater when winterizing the RV or performing maintenance.
6. **Consult the RV Manual:**
- if you have one, refer to the owner's manual or documentation provided with your Forest River Georgetown 398 for specific information on the location and operation of the water heater bypass system.
If you are unable to locate the water heater bypass valves or have difficulty accessing them, it may be helpful to consult with a Forest River dealer or RV service center for assistance.
The first thing to do is to drain the fresh water tank. Drain the hot water heater. Install the RV antifreeze by allowing the water pump to be pumped into the water lines by opening the valve for this process. Open each water valve on all the sinks and the toilet valve as the RV antifreeze is being sucked into the water system and run until the color changes to the color of the antifreeze. Allow each trap to have antifreeze in it also, sinks, shower drain etc. Remove the inline water filter if one is installed and install the bypass plug in its place.
I actually am not able to get rid of the antifreeze taste from the water system so I blow air into the hot water tank drain at a low pressure until all the valve at each place water is controlled. Do not forget the outside sprayer and the shower hose and the shower head.
I allow the pressure to build up to 20 psi or so and then go into the unit and open each faucet until all the water is pushed out of the lines. Then I dump antifreeze into each P trap. Do not use the antifreeze used in the engine cooling system but the non toxic type made especially for RV water systems.
This might not be much help, without more details, but there should be a valve inside the water heater panel (outside) you can open. Open the valve at the main propane tank also.
Make sure the water tank is FULL before you fire it up. There should be a switch inside the coach somewhere to turn it on.
If it doesn't ignite immediately, you probably have air in the lines. Light the stove and let it burn for a minute, then try the hot water tank again. Might take a few tries to get it fired up.
On the back side of the water heater you should see a water line connection at the bottom and one at the top. There should also be a water line connecting between the top and bottom lines. The bottom is cold water input and should have a valve. The top is hot water out put and may or may not have a valve, depends if there is a check valve installed. and the connection line between the two will have a valve. If you are wanting to bypass close the top and bottom valve and open the middle valve. If you are wanting to use the water heater, open the top and bottom and close the middle valve. Open the Hot Water on your kitchen sink and wait until you have a steady flow of water before you turn on the water heater.
Connect the trailer to the city water supply, turn on the water and open each faucet until clean clear water is present. Don't forget the toilet and outside shower if equipped. Next reinstall the anode rod (suburban) or drain plug (atwood) into the water heater. Go to the back side of the water heater and close the valve on the pipe that connects the cold (bottom line into water heater) and hot (upper line out of the water heater) and then open the bottom cold water line valve and, if equipped, the upper hot water valve. This will fill the water heater. Open the hot water valve at the kitchen faucet. When the water flow is steady the water heater is full and ready for use. If the unit is equipped with a water filer, after all is flushed out, turn the water off and remove the filter housing. Install a new filter and re-secure the housing and turn the water back on. If you are using the fresh water pump, it is possible that the winterizing valve for the pump was left open. If so, close that valve which will divert the pump back to drawing from the tank.
Double check that by-pass valves are in proper position, as well as any winterizing valve is in the off position. Some units have a winterizing valve and hose to put in jug for winterizing, that needs to be shut off otherwise it will suck air. Back of water heater- lower fitting is for cold water in, valve should be open, and top fitting is for hot out, which should be open as well. Any valves that may be in between those 2 lines such as a "t" between lines should be in off position. Keep in mind, water heater has to fill first before any good pressure will come out taps. I normally open bathtub hot tap because it\'s less mess and let it run until i get good steady flow from faucette, then do the rest, hot cold.
Water heater must be FULL of water first. Be sure to bleed all air out of hot water lines all throughout the unit. Check water in heater by purging the PT valve at the top. (The one with the little lever). If no water comes out, there is no water in the heater. You can't heat water is there's none in it to heat!
It is possible that there is an open valve on the back of the water heater which is allowing the hot and cold to mix. Locate the back of the water heater. You will see a water line going into the bottom of the water heater. That is cold water in and there will be a valve on that line. It should be open (The handle inline with the direction of the pipe). At the tope there will be another pipe coming out. That is the hot water out. It may or may not have a valve but if it does make sure that it is open. Then there will be a water line connecting the top and bottom water lines and it will have a valve in it. Make sure that the valve in this line is closed. That is a winterizing bypass valve. If this does not correct the problem let me know and I will give you more steps to consider.
At the back of the water heater there will be a series of valves. One on the bottom, sometimes one on the top and then one in a line that connects the top to the bottom lines. Make sure the middle valve is closed and the top and bottom valves are open. If there is not a valve on the top that can be manually opened and closed then there is a check valve installed. This check valve will allow the hot water out of the tank but will prevent the back flow of cold water during the winterization bypass. If the valve on top is closed it will not allow hot water out. If the middle valve is opened it will allow the cold water to mix with hot water and defeat the purpose having a water heater. Close the middle open the top and bottom. If there is not one on top then the check valve is probably clogged or has failed and need to be cleaned or replaced.
