Check that the paper size is correct on your machine then turn it off and on and the device your printing from. basically reset both. if that doesnt solve it check that the driver is correct reload driver and check connections
Try cleaning the corona wire on each toner cartridge. This may help solve your solution. If this does not help try another thing. Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended. To see how to replace your toner cartridges check here
Go into Service Mode and perform an EEPROM reset: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode. Service Mode Operations 1) With the printer powered off, hold down the resume button and press the power button. 2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain lit in green. 3) Select one of the following service mode functions by pressing the resume button the specified number of times. Press Resume Indicator Functions Zero times Green Power off the printer 1 time Orange Service test print 2 times Green EEPROM information print 3 times Orange EEPROM initialization 4 times Green Waste ink counter setting 5 times Orange Destination settings 6 times Green Print head deep cleaning 7 times Green CD-R test print 8 times Orange CD-R print position correction (horizontal) 9 times Green CD-R print position correction (vertical) 4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue. Link
is this problem happens during pc printing? if yes, your machine most probably enabled its dept. id mode. you can input your id code at the printing preferences, then go to job type tab. :)
Service Mode This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode. Service Mode Operations 1) With the printer powered off, hold down the resume button and press the power button. 2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain lit in green. 3) Select one of the following service mode functions by pressing the resume button the specified number of times. Press Resume Indicator Functions Zero times Green Power off the printer 1 time Orange Service test print 2 times Green EEPROM information print 3 times Orange EEPROM initialization 4 times Green Waste ink counter setting 5 times Orange Destination settings 6 times Green Print head deep cleaning 7 times Green CD-R test print 8 times Orange CD-R print position correction (horizontal) 9 times Green CD-R print position correction (vertical) 4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
