SOURCE: internet/ mms setting (PLEASE!!!!!!!!!)
Mine works fine- here are my settings on thePrada (multimedia settings for messages)
T-Mo MMS as connection
Proxy port is 9201
Proxy IP is 216.155.165.50
Internet mode is WAP
Profile name is T-Mo MMS
MMSC is http://216.155.174.84/servlets/mms
hope this helps
SOURCE: LG Shine CU720 -cannot access the internet or mms-unlocked phone from Telstra
I have an Lg Shine CU720 and I can't unlock it. Can you help me please. I need an unlock code.
SOURCE: Samsung SGH-A411 Network Unlock Codes
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
SOURCE: Bigpond Email Customer Service Call 1-805-225-6690 We are 24 Hour Available Call Now for Help
Sorry you are having this problem,
Sounds to me like your eMail client configuration is incorrect...
Is this a new problem where you were able to send an receive mail no problem before and now this ?
I suspect it is a new set-up.
It looks like you entered your eMail address where the software was asking for the address of the SMTP mail server...
Port 465 is for a secure SMTP Server.
Normally, the SMTP server port is 25 or 26.
Have you modified your eMail settings lately ?
Or maybe it works well from home but not when you are on another network....
Bigpond has implemented some security on their network, see here:
http://bigpond.custhelp.com/cgi-bin/bigpond.cfg/php/enduser/std_adp.php?p_faqid=5562
So, when you are connected to the bigpond network, you must use their SMTP server:
mail.bigpond.com
Otherwise, it will reject the connection.
When you are away from the bigpond network, you might have to ask your host or whoever, who provides the highspeed internet access ?
and then google for their smtp server,
ex: securenet.net smtp server
earthlink smtp server
you will quickly and easily find this server and all you have to do is enter it temporarily into your SMTP server field in your eMail client settings
making sure to set it back to bigpond once you are back home..
THis should get you back on your way again.
SOURCE: Wondering how to access optus 3G off a telstra phone
hey i have fixed this problem on my phone (htc touch hd, telstra) and this is how i did it- go settings, connections, go advanced tab down bottom, click select networks, click new on the top bar under programs that auto..... enter in OptusInternet (exactly like this).... then click modem tab down bottom then click new..... enter in OptusInternet again and chance cellular line bar to cellular line (GPRS, 3G)... then click next and for access point name type in internet.............. click ok ok x and then load up internet explorer and it should work
However the current problem i am still facing is opera wont run..... explorer will but opera doesnt load. just sits there untill it comes up with error 104 blah blah blah- still working out how to fix this as i hate internet explorer and opera is way better (going to try downloading opera 9.5 beta again and see if that works)
