run the cleaning cycle in the software for your printer. Sounds like your ink might have gotten a little dry and clogged up. run the cleaning cycle in the software for your printer. Sounds like your ink might have gotten a little dry and clogged up.
You can't post conmments that contain an email address.
This sounds like your word program and not your printer. The information from your word program is not being sent from the DLL correctly. Try a different word program or try reinstalling word. Phill
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Hold down the Stop button as you press the On button to turn the Epson Stylus CX back on. Hold down both buttons until the On light begins to flash, then release the buttons.Tell me the result-->Nozzle check pattern with no gaps or with gaps?
You can use this service/repair manual for Epson dx7400 ->start download.
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
Hey Danzo,
This error is usually caused by dirt (usually toner) on the laser lens. There should be a cleaner pad somewhere on your machine (though I am not totally familiar with Oki) that will wipe across the lens.
If there is no pad, you may have to find access to the lens and wipe it manually with a tissue or similar
