LAWN TRACTER MODEL JOHN DEERE LA 140 ,TURNS OVER BUT WILL START
I bet you ment will not start. First check for spark at the spark plug. An easy way to do this is to pull out the spark plug, connect it to plug wire and with the threaded end touching bare metal (do not hold it with your hand)on the engine see if you can see a spark jump across the gap of the plug. Also check if the fuel shut off valve(if it has one it will be between the gas tank and carb) is open.
