SOURCE: Problema de sonido
Si tienes Internet de alta velocidad le sugiero deshabilitar el módem o simplemente eliminarla, es la solución más fácil.
También puede intentar quitar y reinstalar tanto el módem y tarjeta de sonido, o desactivar el altavoz del módem en la configuración del módem.
También asegúrese de que su tarjeta de sonido está configurada como "preffered dispositivo de audio" en el panel de control.
ENGLISH:
If you have high speed internet i suggest you disable the modem or simply remove it, it is the easiest solution.
You can also try removing and reinstalling both the modem and sound card driver, or disabling the modem speaker in the modem settings.
Also make sure your sound card is set as the "preffered audio device" in control panel.
SOURCE: CONTROLADOR DE AUDIO
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers or you might download slimdrivers http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html note: it will find all of your outdated drivers this is a free driver solutions they will automatically search for and find the correct driver
SOURCE: no tengo controlador de red ni de usb ni audio
Download here at msi:
http://eu.msi.com/product/mb/KM2M-Combo-L.html#/?div=Driver&os=XP%2032
Please unzip the file before you install
Good luck
