https://printcopy.info > code=C1-14
Code: C1-14 · Description: Main charger trouble (Color) · Causes: The main charger unit (CMY) is not installed properly. There is an abnormality in the main ...
MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
Sharp Fuser H2-0 Fusing unit
temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING
ON MACHINE*** You have to reset fuser errors with simulation 14.
Push P * C * then 14 then Start (the button you use to make copies)
and it should reset the code. If not then replace the fuser. SM
5-1 should turn the lamp on. If lamp blinks on and off it is the
thermistor, if it does not it is the lamp, but check the contacts on
the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective
replace.
