SOURCE: iDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
SOURCE: Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
SOURCE: Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
SOURCE: Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
SOURCE: Canon DR-5010C when settings are changed to Auto
If you are using CapturePerfect 3, select page size as Auto-detection, detect size by Image width, Deskew by roller & Image, then you will get images exactly as that of the scanned image.
If you ae using CP2, then you can select Auto-detection AND page detection. The problem with CP2 is if the image is less than that of the guide-plate, you will get black background. You can clean this through software.
If you had select B&W scanning and chosen to save file in JPG format, the scanner will report error. JPG is only for Color/ Grey scale.
With CP2, I have observed that sometimes, the changes are not retained, unless you select 'default' first and alter the parameters. This is not found in CP3.
S. Mohan, Chennai, India.
