Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
A
Anonymous Posted on Jun 16, 2014
How much does it weigh? - Sony FD Trinitron WEGA KV-36XBR800 36" TV
1helpful
Why does salter scales round up when measuring grams
Because you have a scale that weighs in whole grams not parts of a gram. You need a more accurate scale like these which weigh to 1/00th of a gram (0.01 grams).
https://www.walmart.ca/en/ip/fashionhome-500g-0-01g-Weigh-Gram-Scale-Digital-Jewelry-Pocket-Scale-Backlit-Display-Tare-Function-Food-Weighing-Tool/531FGVNPN850
Smart weigh digital postal machine ace150 model. How to calibrate manual?
Hello, Mybrand -
Apparently the Smart Weigh brand of products is a subsidiary of Better Basics.
I did not find the ACE150 model of the Smart Weigh digital postal scale for sale on the Better Basics website. Other Smart Weigh scales sold on the Better Basics site have user instructions availalbe.
Therefore, I suggest you contact Better Basics directly and ask about the availability of instructions for the ACE150 scale. This is the link to the page with the Contact Us information:
https://www.betterbasics.com/searchresults#?query=ACE150
Best wishes.
How many ml is equal to 18mg
Depends what you are measuring. You need to repost with the material that you are measuring.
For example, 1 litre of water weighs 1 kilogram.
So, 1 litre of water weighs 1,000 grams.
Thus, 1,000 millilitres weighs 1,000 grams
So, 1 millilitre weighs 1 gram.
Thus, 18/1000 millilitres weighs 18/1000 grams.
I get 0.018 ml = 18 mg.
Good luck,
Paul
How much does each man weigh?
Jake 120
Joe 240
John 360
If this is homework, be sure to show your work.
Jul 31, 2014 • Watches
How can I weigh my dog, it will not hold still on the scales?
This is really easy! Weigh yourself alone, then weigh yourself holding the dog, then subtract your own weight from both of you's weight. You can also ask your vet to weigh your dog for you.
If a pig weighs 30kg plus half its own weight, how much does the pig weigh? how is the answer 60kg
It is easy. The pig can only weight once = so make it X.If it weighs 30kgs plus half of it weigh so it it simple when you know it is 60. Then X is 60If it does weigh 60 - so it does weigh 60x1/2 (which is 30 = half of its own weigh) plus 30 which was given at the beginning.
If you do not know the answer - there could be lots of answers. This is a tricky question.Regards
1helpful
Tells different wieght each time
Does it tell you a different weight each time you weigh yourself in the same few times? Or day by day?
If its consecutive uses that give you different weights, if you're within 0.2kg, I wouldn't be surprised if the scale can't do better.
Otherwise, weigh yourself each day at the same time, and take an average of 3 weighings for the 'best' weighing.
Nitrous bottle weight
20 pounds is what it holds, what the bottle weighs depends on what it is made of. A steel bottle and an allumnium one will weigh completly different but still hold the same amount.
Kitchen scales & weights
Hope this helps,plz let me know
JonnieC
Weighing 1
006s1.gifWeigh 1 2 3 on the left and 4 5 6 on the right
If the weights are even go to Weighing 2a
If the left side is lighter go to Weighing 2b
If the right side is lighter go to Weighing 2c
Weighing 2a
006s2a.gifWeigh 7 on the left and 8 on the right
If the left side is lighter then weight 7 is the answer
If the right side is lighter then weight 8 is the answer
Weighing 2b
006s2b.gifWeigh 1 on the left and 2 on the right
If the weights are even then weight 3 is the answer
If the left side is lighter then weight 1 is the answer
If the right side is lighter then weight 2 is the answer
Weighing 2c
006s2c.gifWeigh 4 on the left and 5 on the right
If the weights are even then weight 6 is the answer
If the left side is lighter then weight 4 is the answer
If the right side is lighter then weight 5 is the answer
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
