Question about Electric Strider Midi 4 Wheel Mobility Scooter - Midnight Blue
Can i get kymco midi 4 an alternative throttle pot 5kohm
Kymco Midi XL slows down then speeds up. Battery ok
Hi, Kenneth and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
http://scooter.wikia.com/wiki/Tuning_a_carburetor
How To Fix Surging Carburetor with Taryl
KYMCO ForU Midi XLS Owner Manual
Kymco Mobility Scooter Parts Spares WheelieGoodMobility co uk
http://www.discountscooters.co.uk/user-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 13, 2017 | Kymco Motorcycles
I have an error code of 7 Flashes = drive lever not central, but it is.
hi, the lever maybe but is the actual throttle pot stem ? look a the screw slot located a the end of the pot stem ? bet you it's slightly to the left or right ...
Regards
Rob
www.gewizrepairs.co.uk
Mar 10, 2015 | Electric Strider Midi 4 Wheel Mobility...
My kymco midi goes ok for about 1 mile then slows and then stops the battery ok can it be the motor
Hi there i would get it fully serviced before it breaks down completely a full service would cost you 50 pounds
Pete
Oct 09, 2014 | Kymco Midi XL 8mph Mobility Scooter with...
Hi, Ghost midi pickup on MF guitar : Midi volume wiill not increase progressively. Look at data input in computer : controler 7 data from 0 to 15 = no sound then at 16 sound will be audible but already...
The first thing is to verify the pot you are using has the correct taper... there are several types and the nomenclature is NOT too consistent. The second thing is to measure the voltage out of the pot to make sure it covers the range between the outside terminals. After that measure the voltage across the pot... I suspect it might be 5 volts... if you find it way below that, that would certainly be the problem. Note: I do not have schematics for this product and my comments here are based upon my engineering experience and how this sytem is likely to work. The MIDI convertor MAY use a PIC processor or similar.
Dec 03, 2010 | Graph Tech ghost Acoustic MIDI System -...
Hi my days strider midi4 keeps going in reverse for about 4 seconds after you take the throttle off
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Nov 18, 2010 | Electric Strider Midi 4 Wheel Mobility...
My son's 2005 Kymco TGB 50cc scotter hit a good
Normally, one goes to the carb, one to the gearbox and one to the battery. What sounds really weird is the diameter of the hoses. Three quarter and one inch diameter? Normally 1/4" to 3/8".
Hope this helps!
Please rate this solution. Thanks locjaw69!
Apr 04, 2009 | 2005 Kymco Stryker 125
Electric Strider Midi 4 Wheel Mobility Scooter - Midnight Blue Logo
57 people viewed this question
Top Electric Health & Beauty Experts
Rob Hill
Rob Hill
jws1013
Arnie Burke
Arnie Burke
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
