Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman GDO reverses itself when the door reaches the eyes
The door reverses, light blinks 10 times. I have checked the alighnment of the eyes, they seem ok, have the green lights on.
    President:
  • 3,197 Answers
The only thing that will cause the main light to blink 10 times is a sensor problem. Sometimes the sensors will be misaligned just enough to turn the light on but will not work properly. If you look really close (on your knees) you can see the receiving sensor blinking ever so slightly. Tweak the sensors until the light glows constant.
Posted on Jun 26, 2009
6ya staff
SOURCE:
Lift master door will not close with remotes. to close door, the main switch in garage has to be held down until door reaches bottom. when using either remote or main switch, to close said door, the...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. Tweak them a bit. Check the wiring for breaks or shorts. Nothing else will cause this problem.
Dec 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2hp garage door opener (HBW0777 year 1994). It won't close and goes back while blinking 8 or 9 times. Transmitting sensor (red light) is blinking 3 times (even i hold the two sensor...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. If the transmitting sensor light is blinking it is bad.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chain removed or on - eyes aligned and both eye lights on - button starts cyclemotor runs short while and then reverese - no limits have been reached - even removed the ''middle limit arm'' and still...
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure neither light on the sensors is flickering ever so slightly. Sometimes hard to see. If the main light doesn't flash 10 times then it is probably the RPM sensor board. This is a small printed circuit board just in front of the motor. It's job is to reverse the door when it runs into something on the way down but it will give this problem when it goes bad.
Feb 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have sears opener #139.53989. Every once in a while I have a down problem. It goes down within an inch of the floor and reverses. Sometimes I can hold the wired remote button and it will go all the way...
If the main light flashes 10 times when the door reverses it is a sensor problem. Check them very closely. If they are just a little off one of them will be flickering but it is difficult to see. This can also cause the problem to be intermittent. Tweak them just a little.
It is normal for that light to blink randomly.
Jan 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door won't close, blinks 10 times, sensor light yellow
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem or the wiring to them. Nothing else causes this symptom.
Sep 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 HP Craftsman Garage Door Opener works but lights don't
I think you are saying that normal incandescent bulbs do not work. If that is correct you should unplug the unit and using a small screwdriver reach into the socket and pull out slightly on the center contact.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster gdo won't operate with door or remote
Hi there, when the problem first started was the door being used frequently? If your GDO was used quite a few time's in a short period of time the "overload" may have triped. The makers of all GDO's now adays install an overload witch is an electrical safety device protecting the motor. This prevents over heating in turn burning up the motor. To rectify unplug for 15-20 mins. If you have Model number 1270 turn to pg. 7 in owners manuel. Insure all door locks are free. Insure power to electrical outlets by pluging desk lamp in same out as GDO. what model do you have?
Mar 17, 2009 | liftmaster Chamberlain Garage Door Opener...
Motor moves 5 in" and reverses and light blinks 5 times
In the manual it says if you can hold the wall button down & door closes. You have a short in the wiring to the reciever eye. Try substituting some new bell wire in its place, or test the wires for continuity.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,128 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
