Vivitar ViviCam 5385 Digital Camera Logo
A
Anonymous Posted on Jun 16, 2014
My camera won't turn on when I push the power button
1helpful
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Why won't it start?
Here are a couple of things you can try:
Turn the lens clockwise then push the power button. As soon as you hear a click when you turn it push the power button and it should power up. Or
1. Push the power button.
2. double-tap the play-button at the bottom and the screen should activate. If so, push the menu-button. Go to settings and choose reset.
mendmy com How can fix my samsung camera help plz Cameras Film Cameras...
You may find this thread interesting, and helpful...
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Kodak easyshare c1530 won't turn on after slighty dropped
Hello Doris, You can "GENTLY" try to push the lens slowly back into the camera with the palm of your hand, note I said gently and slowly, do not use force !!! Then turn on camera and see if this helped, if not it is repair time.
I have a vpc-E1500tp and it won't turn on and it won't charge... What do I do?
Lens is not all the way extended, so you can not turn it on. the defect maybe fixed buy pushing on the power button and pull the lens out gently by wiggling the lens? It may all be futile. Buy a new camera.
Mar 30, 2012 • Cameras
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
