Admiral AW22 Top Load Washer Logo
A
Anonymous Posted on Jun 16, 2014
Can i wash with hot water only
Do i need cold water or can i wash with hot water onley
Narinder Chhina
Level 2:
New Friend:
  • Expert 153 Answers
  • Posted on Nov 12, 2014
Narinder Chhina
Expert
Level 2:
New Friend:
Answers
153
Questions
Helped
42904
Points
288
You can but rinse cold only
2 Related Answers
Anonymous
  • 26 Answers
  • Posted on Nov 26, 2008
SOURCE: My Admiral Washing machine only runs the hot water (not cold)
the water temp switch is bad call aplience parts store in the area
Anonymous
  • Posted on Mar 24, 2009
SOURCE: No cold water rinse
called a repair person.
I have a mira duo shower why does it make a high pitched squeal when in use the shower is onley 3 months old and has done this from new
Hi Derek
I trust you are well
Sounds like it might be a air bubble in the waer pipes, try removing the shower head and run the hot and cold water together for a minute, then remember to FIRST TURN OFF THE HOT WATER then turn off the cold water and replace the shower head and test as normal.
Hope this helps
Kind regards
Aug 15, 2014 • Home
2answers
There is a hot water valve & a cold water valve on the Dexter T300 machines but it is a 2 coil valve. does the hot water valve supply only hot water or does one side provide water to perhaps the...
supplies hot water when needed, cold water when needed. and then warm water when needed. so the second coil is for warm water. it basically mixes the hot and cold water.
2helpful
Cold water fill does it heat to temputure requied?
If your washing machine has inlets for both hot and cold water, you should connect both if possible. If you can only connect cold water, the washing machine will still work and heat to the required temperature, but it will need to heat the water in the machine, so the wash cycles will take longer and it will use more energy.
If connecting a hot and cold fill washing machine with cold water only, you will need to connect a Y-Piece for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine.
Please post back if you need further assistance.
Regards,
BElectric
Cold/cold wash uses hot water wash and warm rinse. I have t set to hot/cold wash to get cold water wash.
probably the water inlet hoses are hooked up cold water line to the hot water inlet and vice versa
Warm Wash: Force it to be cold?
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
2helpful
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
FP Hot water used when cold selected
YOU NEED TO CHECK THE WATER TEMPERATURE AFTER THE TUB IS FILLED WITH WATER WHEN COLD IS SELECTED. NEW MACHINES WILL USE BOTH THE HOT AND COLD WATER VALVES TO FILL THE MACHINE. THEY DO NOT WANT YOU WASHING WITH STRICTLY COLD WATER AS THE DETERGENT WILL NOT PROPERLY DISOLVE. COLD WASH TEMP SHOULD AVERAGE 65-70 DEGREES.
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Top Admiral Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
