Dell 924 All-in-One InkJet Printer Logo
A
Anonymous Posted on Jun 16, 2014
Dell black ink cartridge carrier lid broken where can i find one/dell all in one 926
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Nov 14, 2008
SOURCE: Dell 926 Printer ink refill instructions
i want to know how many contanners the printer users.
i don't have this type of printer, but this is waht you are going to do. take one of the empty cartridge and scratch the nuzul on a what peace of paper. this in most cases will give you small lines which you can use to identify the colour.
if you can do this it will help you
go to a shop with the printer number, where they sell printer cartridges. Tell them you want one of the cartridges, if they have take a close look at them and tell you will came back later but ask them how you will know the black ink since you want to buy that one.
in this way you can identify the two
thank you
Anonymous
  • Posted on Jun 13, 2009
Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
Anonymous
  • 50 Answers
  • Posted on Aug 21, 2009
SOURCE: installing an ink cartridge
Just open the top and wait for the carrier to come to a stop and then take out the empy ink cartridge and put in the new one.
Rossiman46
Rossiman46
  • 50 Answers
  • Posted on Nov 06, 2009
SOURCE: How to install ink into printer 926 dell
There should be a button on your printer, you would need to press it in untill the carriage moves over into the install new cartridge position, you will know when it happens you should hear it.
Take out old cartridge 7 install a new one, normaly when you shut the lid down the printer will automaticaly do a head clean better known as priming the cartridge, you should then be ready to print.
Testimonial: "Didn't find any button to push"
mstanicek
  • 11 Answers
  • Posted on Mar 23, 2010
SOURCE: I refilled my dell ink cartridges from Costco. Now
The ink is fine in the cartridge. The ink level indicator just thinks the cartrdige is still empty. You can ignore the message or turn it off all together. Just bring in your cartrdige for a refill when it shows signs of fading or streaking. Go to www.inkjet411.com for more help
How do i put in ink on 926 dell photo scanner and copier
From the online manual...
1. Turn on your printer.
2.Lift the printer unit, and then position the scanner support between the tabs to hold it open.
3.The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4.Press down on the ink cartridge lever to raise each ink cartridge lid.
5.Remove the old ink cartridges.
6.Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
9. Snap each lid closed.
10. Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
Manual can be downloaded here.
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
  • 0helpful
    DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
    Follow the below instructions
    1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
    2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
    3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
    4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
    5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
    6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
    7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
    I hope this clears up your problem.
    Good Luck and Have a Nice Day!!
    2helpful
    How do I install the printer cartrige? I do not have the booklet...
    2. Open the front cover.
    1. Press the tabs on the cartridge lids, then lift the lids.
    1. Remove the old ink cartridges.
    1. Store the cartridges in an air-tight container or dispose of them properly.
    2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
    1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
    1. Snap each lid closed.
    1. Close the front cover. The front cover must be closed to start a print job.
    1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
    2. Click the Maintenance tab.
    3. Click Install a new print cartridge.
    4. Click Next.
    5. Select the type of cartridge you installed.
    NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
    1. Click Next.
    3answers
    1helpful
    Where is the ink cartidge compartment??
    just raise the top lid and the cartridges will come to the center and stop
    2helpful
    Hi there
    Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
    2answers
    Ink cartridge carrier jam
    If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
    2answers
    Carrier jam
    This fixed the problem for me : found it on the Dell support website:
    Reposition the Encoder Strip
    1. Remove the power cord from the printer.
    2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
    3. Gently slide the ink cartridge carrier to the middle of the printer.
    4. Gently move the top part of the printer belt to the right.
    5. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
      new_note.jpg Note: There is a small slot on the back of the ink cartridge carrier, into which the encoder strip fits.
    6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    8. Once the encoder strip has been re-seated, close the scanner lid.
    9. Re-connect the power cord to the printer.
    Top Dell Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Norman Weimar
    Norman Weimar
    Ngoro
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
