Hi there.
go to this link and see if it helps you get it sorted.
How to Fix DVD Player When the Drawer Won Open Techwalla com .
or this one.
DVD tray will not eject the movie Google Search
SOURCE: Can't program my remote to
Although you didn't explain what brand of universal remote this was for, all universe remotes have a code search option for this situation. Check the manual for your specific remote control for more details.
Often manufacturers of multiple brands will use the same infrared (IR) codes for all of their brands. For example, Panasonic and Quasar share the same codes as their parent company is Matsushita Industries. In your case Funai is the parent company of Sylvania and the parent company of Magnavox so you might want to try the Magnavox codes before doing a code search. As Funai also manufactures televisions for Toshiba and Sharp, so try those codes as well.
SOURCE: how to eject dvd
Someone needs to look inside to see if something got inside and is stopping the mechanism from working---I have even seen a few which someone had managed to get 2 discs in at same time.
If the mechanism is damaged it may not be worth repair as the DVD portion (if even available) costs too much.
SOURCE: My sylvania tv/vcr keeps ejecting when it has
Not likely to be worth repairing but if you can get it apart look at the mechanism when you plug it in.
These units (all brands/models) have two light sensors (one on either side of tray) and if blocked with something will instantly try to eject the tape--they usually stand up and have a clear LED and could be bad or even broken loose from the board---when a tape goes in it blocks both and machine switches to load--pulling tape in and down---if one is bad or one covered you could have this problem.
Look also if you open it for some item that does not belong inside like a coin etc.
