You have to be sure the battery has a full charge, if the battery is down, you can't do any testing. Use a digital multimeter across battery posts everything off, the generic spec for a full charge is around 12.6 volts, if it needs charging, get it charged.
Test the charging system? Even if the generator is new, if a problem on the wiring circuit, it may not work.
If starter motor won't even crank have to check starter motor wiring circuits. When testing make sure tranny is in park or neutral and parking is set. Safety is your responsibility.
If it cranks good but won't start, check spark--fuel--compression. What about your security system?
The pull cord is like a starter on a car (separate
from the motor/engine). If the pull cord will not turn it could be because the
motor/engine is seized.
Interesting. They haven't used generators in over 50 yrs. But yes that was the warning light for the generator. If you have a volt meter that would tell you what the system is doing. If the engine will not crank, and the battery is fully charged, you would need to check the connections at the starter for voltage and ground. And the red warning lights would normally come on until the engine starts.
If your battery is old or low then it may not have the power to run the PTO. It also depend on the size of the object that you are trying to operate off of the PTO shaft and if your engine can take it. Only the rear PTO is live or uses generated electricity. The front one is independent so it probably runs off the battery.
Figure by everything else you mean the radio,lights,etc? Is the engine turning over? What happens when the key is fully engaged? If the engine does not turn over the first place to look would be your fuses. Ensure that none look to be burnt or blown.If so replace and try again.If fuses look good Next step would be to ensure starter connection is good and starter is turning over.If the starter is not turning over then I would focus on it.Hope this helps.
Sounds to me like the battery hasn't enough charge to turn the engine. Taking the starter off and testing it doesn't require much power as it doesn't have to turn the engine. Check the battery and also that the charging system is charging the battery back up.
Alex.
Yes you can install an electric starter on your generator if the following conditions are present. Starter/fan cover has cutout for starter, the flywheel has ring gear and block has taped holes to mount starter. Examine the engine where the starter would normally be installed (look at a generator like yours with the same motor that has the starter installed ) and check that the mounting holes are there and threaded to receive the bolts. If threaded holes to mount are there and access thru starter cover to flywheel is there, check that the flywheel has a ring gear where starter motor engages. If all present starter can be installed however you will not have the charging coil which is normally under the flywheel to charge battery; but you can still use the generator to charge the battery. To locate parts, use model number of the engine not the generator. Good Luck
First, charge the battery.(Always do the easier things first). If that isnt the problem, take a DC volt meter and check the voltage where the battery connects to the solenoid. Then check the voltage on the starter side, while you turn the key,If there is a large voltage drop, or no voltage, replace the solenoid. If voltage okay, then check the starter. Good luck...Lee
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
