SOURCE: I'm trying to pair my jabra bt2080 with my ps3 and
This bt2080 is not work with ps3 because your ps3 bt is ftp profile and it ask for pass key and we can't enter passkey in bt2080
SOURCE: i need the passcode for the jabra bt2080
It's '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, feel free to download it from this location (mirrored here, just in case you, like me, happen to face problems with the official site).
Hope you are able to sort your problems out soon.
Regards,
Carlos
SOURCE: trying to connect jabra BT2080 to phone. says
In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection. You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves. Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed. With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices. On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
SOURCE: Jabra BT2080 - been working
This problem is mostly associated with the battery of your device. In some cases, the battery is most likely to have expended it's lifespan.
In this case, all you need to do is to change the battery. It is advised that you get a professional to change the battery for you as trying to do this yourself could lead to a damage in the device.
SOURCE: how do i connect my headset jabra bt2080 to my
I also have laptop hp 620 and the jabra bt2080 which are working through a driverless bluetooth usb dongle v2.0 (China) after installing jabra pc suite_2.5.6. It is under my experiment as at the moment only the mic is working when you start windows speech recognition program. i am trying to get it working as playback device to listen music instead of headphone through jack.
