SOURCE: MESSAGE REPLACE/ INSTALL TONER WASTE TANK EVEN THOGHT I HAVE REPLACE IT ON A SAMSUNG CLX-3160 FN
When this happened, I took the tank out and shook it out into a garbage can (do this outside and be very careful not to breathe the dust). I then took a shop vac and held the hose at the opening while blowing compressed air into the tank. Wiggle the air nozzle around and you'll get out 99% of the toner. Pay extra attention to the sensor optics (plastic bulges on the sides of the tank).These need to be clean since the printer knows when the tank is full because the toner blocks light shining from one side of the tank to the other
Reinstall the tank and be sure it is fully inserted. If they printer is still on, turn it OFF. Close the front door of the machine and turn it back on.
Continue printing.
SOURCE: samsung clp 315 printer shows "replace/install
Hi there your printer wast toner drum is full. So just remove that and make empty the drum & then refill the toner box. now use. Thanks.
SOURCE: the wast toner bin on
Open door where toner cartridges are. On left side of cartridges below the Colour Letters is a small black handle. Just pull the handle and the bin comes out. You can't simply empty the bin and re-use, you need to order a new one from Samsung. Only costs $25 and just push in. Very easy, just need to wait for part to be ordered in and then collect it, which took me a week.
