I have installed a Belkin N600 (F91101v2) USB adapter in a Toshiba Satellite NB10t-A laptop, running Windows 8 64 bit O/S. I downloaded the latest Windows 8 software driver from Belkin web site: V2 (filesize is 24.9MB). The software driver installs and the Belkin adapter is listed in device manager ok. I need this adapter to work in a School which requires 802.11 a/b/g/n '5GHz' only WiFi connectivity.
SOURCE: how to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem? This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet. something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection. If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01 or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
SOURCE: Belkin Wireless G USB Network adapter F5D7050
your wep key is wrong
go to a pc thats hardwired to that router and u need to type in browser 192.168.1.1 if its linksys, if its belkin or either brands the second to last digit changes e.g. 192.168.0.1 or 192.168.2.1 u need the default password and check wireless settings.. security.. wep key 1 copy it and use that to connect.
and easy way to find more is portforward.com
SOURCE: Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
SOURCE: windows xp sp2 doesn't recognize and software will not let me connect to router
First of all you have a wireless "N" adaptor running on a router set for 802.11g. You need to have the same router as the adaptor, "N".
SOURCE: Drivers for my Belkin wifi adapter mod.# F5D6050 .
go to this website and select your correct OS
follow this link
