Frigadaire temp light will not go off but still cold
Do not know if you mean the cavity light or the power indicator light at the outside bottom of the door. The power light is always on when there is power to the unit. it could be red or green. The light switch could be shorted closed or open depening on the MFG design. Rare but can happen, ground short through light wiring. Access / remove light switch, remove one of the wires. If the light goes out...the switch is bad. If possible and you have a multimeter and know how to use it. Remove both switch wires and with unit unplugged measure resistance to ground. open - zero through load L1, continuity through neutral. Plugged in 120v between load L1 & ground, zero volts between Neutral & ground. Keep bulb in receptical. Call qualified tech is not sure how to use tools to test.
