SOURCE: fax line stays busy continously...
Are there any other phones that use that line? If you have a phone attached to the fax machine, is the reciever in the holster all the way?
SOURCE: Error Message
Try plugging a phone, with a different cord, to the wall outlet the B640 is using. Do you hear a dial tone? If you do, replace the existing phone cord going to your B640. Now press the "hook" button on your B640. Do you hear a dial tone? If you answered yes, what messages are you seeing displayed now? Once I know your answer, we can take it from there.
SOURCE: How do I set the phone to ring 5 times before going over to fax?
Press Funktion,Dataregistraion,press ok,Usersettings must be on the display,scroll with the arrows until you get RX settings press ok,scroll with the arrows until you see "incomming ring" press ok and change to yes if it was set for no.The next step it will ask you for ring count press ok and set it for 5 press ok again.
SOURCE: how to connect canon L295
Hi THe main difference in the phone fax line is that if you are only using as a fax plug the cable from phone socket into the line socket sometimes this may be marked line/tel then the hand held phone goes into the tel socket.this should make it a little clearer..line to wall socket ....and tel to hand telephone
SOURCE: My canon fax L220 is
Hi there!Please make sure that the line is pluged into the"L" Socket on the machine and it will go back to normal!Good Luck!
