SOURCE: Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
SOURCE: The picture on my monitor
Establish what the recommended (native) resolution of your monitor is, and set the display resolution of your computer to the same values (in Windows right click an empty area of desktop, choose Properties, Settings tab, move resolution slider to the right to the right until proper values are set, confirm).
If you can't set the resolution to more than 800x600, it means that you need to install a driver for your graphics card.
SOURCE: The picture on the screen is stretched to fit the
Try right click on the desktop and choose display or personalize, or a call close to do the display settings.
SOURCE: I havew a gateway FPD1975W monitor and I can not
You need to set your PC video resolution to the native resolution of this monitor: 1440 × 900 @60Hz. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
