SOURCE: kenmore freezer
Try cleaning out the drain opening with a pipe cleaner. Or use a turkey baster and force hot water into the drain. Rinse with a mild bleach solution to kill any mold. Another solution is to unplug the unit and let it sit for a couple of days to defrost completely. Sometimes during the humid summer the system just gets over burdened and doesn't defrost completely. This gets progressivly worse until you get this problem.
SOURCE: Need to empty drip pan. How do you remove the
The standard procedure is to remove the plastic grill at the bottom of the front of the freezer and then slide the pan out for cleaning and emptying. Might as well vacuum dust out while your at it. Helps the compressor operate at a cooler temperature.
Please rate this answer for me. Thank you.
