So i turned it off agian. now an hour ago i turned it on agian first it flashed red then it turned blue with white spects and a white stripe dancing around the midle !!! I love this tv I have six kids and four grand children. I added a bed room an bath to a freinds house an finely got my dream tv i love thatbox and if you tell me it can be fixed i will be forever in your dept
SOURCE: 50 inch HP Plasma Gone Wild...
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
SOURCE: i have a HP PL5060N
Behind nearby if you are keeping Magnetic appliance like woofer/speaker.Place it apart and try this may help you
SOURCE: HP 5060 N plasma tv 50 " Screen is Dark (Not alot
Hi, thanks for using fixya..
The Optical Block probably needs to be replaced. This is a major tear down job and a very expensive
repair. Call HP center and see if they are willing to help with the cost of the repair and also to get a local Service out to confirm that it is a Optical Block problem.
I hope this helps,
Bad Caps In the power Supply,Look for Bulged Tops,Replace only If You are a Technician
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
