Making noise when spinning
HI there.This sounds like the centre bearing & seal are worn causing noise & water leak.It's normally called a Hub & Seal Kit.It is quite an involved job & without the right tools it would probably cost somewhere around $300 upwards to have repaired.Very good quality machine & worth while repairing.Try to avoid useing the machine until repaired as you could cause electrical short due to water leaking.
