How to tighting the belt
The belt tensioner is a spring loaded plunger mounted at the 8 o'clock position from the passengers side facing the engine. remove it to loosen the belt. to reset the tensioner compress it in a vise,put a pin in the hole through the plunger and sleeve when it is aligned. When you are ready to tighten.the belt pull the pin out.
There is always a timing belt tensionor in the system. Its a free running bearing on a wheel that is used to compress the T-belt. Find this under the timing cover plate or plastic cover. You may need alan keys or a special socket to tighten the bolts & nuts..
Hi arturo reyna, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? what size motor, body style
