HOW DO I SET MY DIGITAL -- (PUSH BUTTON) -- WATCH
mcdevito75 here, The Quartz Mechanism is made in such a way, that the battery"s electricity changes in a way, while going thru the Quartz and thus Display"s the Numbers and or Letters on the Dial or Display, By PRESSING these Various Buttons, you are Changeing the Battery"s Voltage thru the Quartz and thus Displaying the Numbers and or Letters. ---------- Genarally, you need worry about only TWO (2) of these Buttons to SET your DIGITAL (push button) Watch, They are the MODE and SET Buttons. ------------- The MODE Button is usually on the Right side of the caseing, PRESS this Button, depending on your watch you may have to hold down this MODE Button 2--3 seconds, once you see the Dial Or Display BLINKING you are set to RE--SET your watch, NOW, PRESS the SET Button, usually on the LEFT side of the caseing to change each Function (Hour, Minute Etc.) once each Function is SET, PRESS the MODE Button to move onto the next Function. ------ Once all the Functions are SET, PRESS MODE again to see a STEADY Display or Dial. ---- It May take a little practice so be patient. ------ Some DIGITAL watches may not have a MODE BUTTON, But Rather a DIMPLE on the watch caseing you would PUSH in with a PIN or Tooth Pick, same MODE and SET procedures would apply. --------- Use your watches name plus .com online to obtain a user manual or look for a small watch repair shop in your area to order a NEW owners manual for your watch.
