SOURCE: Fridgidaire Dryer runs constantly when plugged in
You have a couple different options. One is to check the timer and make sure that it is working correctly. Second thing is to check the computer and the fusees to make sure all is well.
SOURCE: high efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
SOURCE: Frigidaire dryer model FSEC346RHS0 When I open
heating element had broken and was shorting out agaainst the frame causing it to get hot.
SOURCE: Dryer runs when door shuts. Only stops when door is open
There is a safety switch in the door that shuts dryer off when door is open. If there is more to your problem let me know. From what you have stated there is no problem.
SOURCE: dryer wouldnt turn on its saying door is open
most of the time. its the door switch that causes this. if door is closed and it does not start, its the door switch. try this! unplug power, remove the door switch, hook the wires from switch together. this will make a complete curcuit.put black tape on wires so it wont short out. plug back in. it should work, if it runs ok door switch is bad. good-day !
