SOURCE: cant get a deck cutting belt for model YTH
which belt do you need the primary or secondary i have part # for ya i can also order them 180808 & primary part # is 174368 let me know if i can further help thanks wade
SOURCE: 48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
SOURCE: There is a big, wrap-around lifting bar in the
most rideons have the deck assembly able to be removed without too much work.usually release any spring tension,then spring clips holding the arms on,then usually you can disconnect the belts and slide the whole deck out sideways,from under the rider.
SOURCE: deck 48 inch 25 hp
Here is your owners manual. Find pages 20 and 22 and you will have what you need.
http://www.husqvarna.com/ddoc/HUSO/HUSO2008_USen/HUSO2008_USen__532424761R1.pdf
You will need Adobe Reader installed on your computer to view this. It is a free and safe download at AdobeReader.com.
SOURCE: how to replace the spindle on a 48 inch mower deck
OK, Now I see your question under a different post. You are going to have to pull the deck out from under the spindle housing and spindle and replace them. They usually come as an assembly. after removing teh deck you should see the spindle housing retaining bolts to remove. Make sure you pull the blade off that spindle before you try removing it.
