Onkyo TX-SR608 Receiver Logo
A
Anonymous Posted on Jun 14, 2014
How do i install samsung sound bar - Onkyo TX-SR608 Receiver
Installing sound bar to a 800D Samsung tv. No sound
There is not enough information in this description to begin giving a possible answer.
1helpful
How install your sound bar to a 800D Samsung tv
The TV should have a variable audio output jack on the back, use that.
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Hooked up HW-D450 sound bar to Samsung UN40D6000SF TV with low output from sub woofer
Have you adjusted the subwoofer level? there should be buttons on the remote to adjust this level. Also, make sure you are not in a 'night' surround mode - this drops subwoofer levels a lot
How do you connect Samsung sound bar to my Sanyo dp52440A. TV has no no outlet which fits audio aux which came with my Sanyo TV
Hook your sound bar to your output device, Cable Box, DVD/Blu-Ray player. Or try the follow should your Sound Bar have HDMI.
Output Device>Sound Bar>TV
The Sound bar should have a HDMI in and out or at least most Samsung models do as well as Bluetooth support.
It is easier to answer when you list the model of each Item, there are many different version of Samsung sound bars.
Connecting sharp tv to samsung sound bar
don't you mean sound bar to tv?
your tv has an input and output for audio and video,find the audio output and connect the sound bar!
Cannot figure out how to connect my new sound bar to my older TV
Use a high speed HDMI cable form the TV to the sound bar. HDMI cables carry sound as well as picture signals. Refer to your TV's user manual http://www.hdtvsolutions.com/pdf/52527-62528.pdf
and the Samsung product support page http://www.samsung.com/us/support/owners/product/HW-F450/ZA for assistance
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
