SOURCE: My Brother 8860 DN does not copies
This is commonly an issue with the Keypad PCB. We can get you pricing on parts if you want to try this as a repair. Does the machine beep 3 times when you hit the copy or scan keys?
SOURCE: Brother DCP 1200 printer/copier...won't copy/print
The scan lock is the switch on the left side of the printer above the fan outlet. You flip the switch to lock it before moving the printer. Flip the switch to unlock the printer
SOURCE: My Brother DCP 7040 printer can only print 1
I've had the same problem with my Brother MFC-9440CN and XP Pro.
Try changing Printer properties (Control Panel\Printers) and click
Advanced\Printer Processor button. Here you can try to change Printer
processor: WinPrint, ModiPrint, hpzpplhn, LMPRTPRC.
I solved my problem choosing hpzpplhn (RAW).You can also try to deactivate 'Enable advanced printing features' in the printer, advanced, properties...
I recommend that you will post your question under
the correct category (printers) and maybe add more details to it, so it will
be easier for Experts to understand the question and answer it.
You can also contact the Brother site directly at http://www.brother-usa.com/askus/default.aspx?PGID=1&R3ModelID=1814#.UIU9F6Puj_Y
