SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
SOURCE: need to know gas oil
50:1
Check this site out:
www.modernoils.com/ATO_Saber_Outboard_100to1_PreMix_Oil.html
Jim
SOURCE: what is gas:oil mixture for Echo PB-500t blower?
50:1 ratio, 2.6oz of 2 cycle oil to 1 gallon gas
SOURCE: What is the fuel/oil mixture
Sometimes, the fuel ratio is stamped on the fuel cap. Your ratio is 50:1. Echo specifies using 89 (mid-grade ) octane Here is a chart that tells you how much oil you need in a gallon of gas...Just 1/2 it for a half-gallon mix. A copy of your manual is also here.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
http://www.echo-usa.com/getattachment/624aee9f-103c-416c-ae9b-55fb42dd94af/PB250es1112_010410_1.pdf
