Timex 1440 Nylon watch Logo
A
Anonymous Posted on Jun 14, 2014
How to get your watch off of military time - Timex 1440 Nylon watch
2 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 24, 2010
SOURCE: How do I get the watch to change from military
Get manual here from my tips and tricks.
Anonymous
  • Posted on Nov 16, 2011
SOURCE: My timex watch is on military time and I can;t get
After much frustration, I found the solution...
Push the set button while on time mode. Push mode until the hour is flashing.Push Split/Reset.
That should be your solution!
Get marathon CL030062 off of military time
To convert a marathon CL030062 (military time) to standard time, simply subtract 1200 from the time and add "AM" to the result. For example, CL030062 in military time is 3:00 AM, so in standard time it would be 3:00 AM.
How to Quit military time on Armitron IW-YP 12585A
Hi Bill.
Please allow me to try to help you.
Here is where you could find the answers to how to quit military time on Armitron IW-YP 12585A...
https://oureverydaylife.com/how-do-i-change-from-military-time-on-my-armitron-watch-12277699.html
http://office.manualsonline.com/support/armitron/clock/how-do-i-switch-from-military-time-to-normal-time--5401972
You could also find help in the form of the video that I have added here.
Hope that helps.
Best wishes. Regards.
8helpful
Athletic works watch that is stuck on military time
With my old watch (from Walmart), all i had to do was go into the time settings and cycle through the hours until it went past the military time's midnight and it would start going through "normal" AM/PM times.
I hope this is enough information.
Feb 15, 2010 • Watches
4helpful
26helpful
2answers
My TGHK watch is stuck in ''military time'' and I've lost the instruction manual. Any ideas how to get it to am/pm mode?
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
Nov 03, 2009 • Watches
7helpful
How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
Sep 23, 2009 • Watches
Having problems with time settings
the instructions for getting your watch out of the (military)24hour mode to the 12hour mode are on this page
http://www.grudknows.com/inanemutterings/watch_baby_bgr210.asp
6helpful
3answers
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 • Watches
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
