I am playing a record that is slightly smaller than the standard 33.3 record (not quite a 45). However, the tone arm is returning to rest about half way through the final track of each side. Any suggestions?
SOURCE: Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
SOURCE: The turntable on my CR245
Haven't worked on one of these, but there is an end of travel arm sensor that needs adjustment, or is possible broken. You will have to get inside to check it out, and adjust or fix it.
If you don't feel comfortable fixing it yourself, contact Crosley support:
http://www.crosleyradio.com/supportForm.aspx
Good luck, and hope this helps.
SOURCE: My record spins fine when
It would appear you have a problem with the "Cuing mechanism" this is quite a common problem. This link below will assist you to understand about it.
http://www.turntablebasics.com/advice.html
What you need to do is locate a service manual for your exact make and model, in there you will find the necessary troubleshooting steps to take to isolate and cure your issue. However I have had a look and have been unable to locate any, perhaps a direct approach to the manufacturer may yield one?
It can often simply be a faulty switch, the "Mode Switch" this is simply replaced, however to obtain this one ,must have the parts number, the ONLY place this is available is in a service manual. Sometimes it is the belt or drive? it is usually something quite simple, often it's obvious once the TT is disassembled.
should you not wish to DIY, simply find a competent Turntable repair place and ask first for a "Quote" once appraised of the costings etc, then go from there.
http://www.ehow.com/how_2086746_troubleshoot-turntables.html
http://www.audiokarma.org/forums/showthread.php?t=37752
below is a link for the user manual...
http://www.crosleyradio.com/Manuals/CR249_Manual.pdf
http://www.vinylengine.com/library.shtml
Above are a couple of sites that may help you if you wish to DIY?
