SOURCE: my samsung impression touch screen
To recalibrate follow this procedure.
Go to setting>phone setting>calibrate
The calibrate screen pops up follow the screen and with the finger or stylus click on the cross image.It will ask for 2-5 times until it is able to detect your response time.Then save the changes.
If you are not able go into menu settings.To make the calibration to Factory setting.(Take back up of all data)
Reset is the only option if you want to take it to the Factory setting.
If you want get it back to factory settings.
full reset:*2767*3855#
default code:000000
If still after the old calibration if you have problem with the touch screen.
Take apart the screen and remove all the dirt and water particles.
If still you have the problem check for any internal component failure.Check flex is properly placed into the socket.If it is defective
Replace flex cable.Flex cost is around $10.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: Ok....the phone can receive calls
You need to just have the whole phone traded in, or the problem will come back again. I thought changing out the screen would work. It didn't. I had to get a new one mailed to me.
SOURCE: samsung jet 8000: when i touch the screen, the
Is there a menu setting to restore it to default settings?(Although Beware if you have set anything specific on it that you might reset)
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
SOURCE: Hello. I have a Samsung
Did you ever get a solution to this problem troy? Having the same problem myself and can't find a solution. Any help would be greatly appreciated
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
